The Plumber: Hello, How do i activate the aux output from my BS9000 in the bathroom (speakers connected to passive amp with eye) from a mk1 beo4?
Why, when accessing your main room sources from your bathroom, you would want to use LINK command preceeding the source you want to use, in this case A.AUX? I take it you don't have other remote controllable B&O in/around you bathroom (linked or not) - here I could be wrong, of course. However, if you don't, then simply selecting the source by chosing A.AUX and GO on your Beo4 should work. (Your BeoLink passive should be in L.OPTION 6, of course).
