I have a Beomaster 4500. The problem that I am having with it is that as I turn up the volume it automatically either rolls the volume back to a lower setting or turns off the Beomaster 4500. I use RL2000 speakers with it. I am very frustrated with this as I can never really get the sound up and hear the true potential of the system I have.
Any ideas?
Carl
I had this exact problem and it turned out to be a defective tweeter in one of the speakers.
Suggest you check the speakers or the cables for a small short from a strand of wire.
Regards Graham
Thanks for the idea.
I will check it out.
