Hi, can anyone help me getting a service manual, especially the section with the motor control, please? The fault is: plugging device in, the lid motor turns downwards. But it doesn't stop when the switch goes on (one tooth is already broken). Touching the "load" sensor makes the motor stop. Usually it should go reverse. Therefore you cannot open. I can only find a manual for the beocord 4500 but this is different. I guess something wrong with the logical values.
