Latest post 01-29-2010 4:29 PM by Ehlerz. 2 replies.
Page 1 of 1 (3 items)
  • 01-29-2010 12:39 PM
    BS9000 mainroom - linkroom audio question
    Hi All
    I am currently considering upgrading my BS3000 to a BS9000, as i have BL5´s and would like the ability to connect them to the digital audio out on BS9000. I have a questions in this matter.
    I currently have my BS3000 with AUX connected to an airport express so i can play music in all linkrooms from my macbook pro. This works like a charm with NO delays across rooms. The question is, if i hook up the BS9000 the same way and use AUX, will the main room play through digital or masterlink?(speakers also hooked up with powerlink to BV 7-40), and if digital, will there be any delay in the linkrooms ??
    I ask because i often have all linkrooms playing simultaneously when i am having a party, and would like to continue having this opportunity, while ALSO hooking my Bl5´s up digital. Two linkrooms are not separated by a door so it is perfectly possible to hear any even minor delay.
    Does the BS9000 only use the digital connection while playing CD´s, as it is not possible to connect anything digital to it??
    Thanks in advance.
    /Ehlerz
    BV7-40 MK IV, BL5´s, BL3´s, BL 3500, BL7-4, BS3000, BC 6-23, BV 1, BS3.
  • 01-29-2010 1:34 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: BS9000 mainroom - linkroom audio question
    Should be fine. I have a similiar setup - BS9000 connected to BV7-40 and digital audio to BL5. Spdif is only used when playing CD. In RADIO- or AUX mode sound is via masterlink to BV7-40 and via Powerlink to BL5.
    In my setup the AUX out of a BS7000 (located in a linkroom) is connected to AUX in of my BS9000, and I can use it in all my linkrooms without any delays - just the "natural" delay, as the speakers are in different places....
    Hope this helps.
    Stefan
  • 01-29-2010 4:29 PM In reply to
    stefan:
    Wow, you must have a huge home :-)
    Thanks for your reply, i will most likely go through with the upgrade..
    /Ehlerz
