I am a little reticent to open up again the 768 / 1080 High def debate, however. I currently have the latest BS3 BV4-50, with the 768 res panel. There has been quite a lot of discussion that 1080 will not make much if any difference when this full HD res panel is shipped later this year.
My point is as follows;
Most DVD and Blu-ray movies are in widescreen format not 16:9, and I believe most people don’t change the format manually as this tends to distort peoples heads etc, so the movies are viewed in letterbox format. On my BV4 something in letterbox mode isn’t using about 20% of the horizontal resolution. So in other words about 614 lines are being used. I think then a 1080 panel will be quite alot better as including losing the 20% there will be about 864 lines in use in letterbox mode?
Regards
Peter
My B&O - BS3, BV4-50, Beomedia 1, BS3200, DVD1, BL8000, BL6000, BL3, BL2, BL7.4
