You have to be a little careful about the "Number of Members On-Line"
because this is updated by a batch job which I have got currently set
to run every 2 minutes on the server. So, its not a real time view of
the situation, its a snapshot every 2 minutes and if the Beoworld server has a heavy load, the running of the batch job
will be deferred for a further 2 minutes.
The bottom line is that the "Number of Members On-Line" figure
may not reflect the actual number of users on-line at that time under heavy load conditions.
