Latest post 01-17-2010 2:09 PM by javammx. 5 replies.
Page 1 of 1 (6 items)
  • 01-17-2010 6:47 AM
    Advice needed on BeoLab 8000 - Year 1999
    Hello All
    I'm a new user on this site and forum, so I'm not sure if this is the right place to ask this question!
    I recently bought a 2nd hand avant 32" crt, and the seller has offered me the BeoLab 8000, year 1999 speakers.  There are two of these speakers with no cables and look in good condition.
    I would be grateful if anyone could suggest what would be a fair price for the speakers or any advice in what I should be looking for if there are any problems with the speakers.
    Many Thanks.
  • 01-17-2010 7:06 AM In reply to
    Re: Advice needed on BeoLab 8000 - Year 1999
    I would say 1000 - 2000 euro depending on the condition. No cables is a few hundred euro less, but check them before you buy...
    -Andreas
    BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
  • 01-17-2010 7:19 AM In reply to
    javammx:
    Hello All
    Many Thanks.
    You need to state your location before a sensible answer can be given.
    Regards Graham
  • 01-17-2010 11:52 AM In reply to
    Hi Graham
    Im in the UK.
  • 01-17-2010 12:38 PM In reply to
    The ~£1200 would seem fair if they are in excellent condition and from a private seller.
    Common fault is blown tweeters, about £30 each plus fitting. If both are gone then that's around a £200 bill for replacement, maybe more.
    New frets are about £70 each and you will need to budget for a pair 'cos you are unlikely to be pleased with just replacing one!
    Regards Graham
  • 01-17-2010 2:09 PM In reply to
    Thank you for the info Graham, it has been really useful. Shall certainly consider getting them.
