Latest post 01-06-2010 11:30 PM by tockvock. 2 replies.
Page 1 of 1 (3 items)
  • 01-06-2010 6:49 PM
    Master Control Panel 5500
    First off, I just want to thank everyone on this forum because you've all been very helpful to me in getting my new Beosystem set up.  Now that that's out of the way, I have yet another question.  The display on my MCP 5500 started blinking about five minutes after I put new batteries into it.  I did a little bit of research and discovered that the display blinks when the batteries are low.  Well, I just put in brand new batteries, but they were cheap ones from a dollar store, so I figured that I had just got crappy batteries.  Then, I bought brand new Duracells and popped those in.  Less than five minutes later, the display started blinking again!  And a few minutes after that, it switched from the cd player to the radio by itself.  What could the issue be?
  • 01-06-2010 11:01 PM In reply to
    Re: Master Control Panel 5500
    Are any of the buttons jammed with dirt or a sticky residue ?
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
  • 01-06-2010 11:30 PM In reply to
    As far as I can tell, no.  They're all equally "clicky."  Although the treble and loudness buttons (which are next to eachother) don't seem to ellicit any response from the Beomaster.  Any suggestions?
