Latest post 01-08-2010 11:14 AM by lztom. 2 replies.
Page 1 of 1 (3 items)
  • 01-06-2010 3:37 PM
    • lztom
    • Not Ranked
    • Joined on 01-06-2010
    • Posts 2
    Beocenter 2600 Speaker Problem
    I've recently resurrected a Beocenter 2600. It is working fine in most respects but there's a tendency for one of the speakers to cut in and out occasionally. Is there any obvious cause of this/place to start in working out what is causing it?
    Thanks in advance,
    Tom.
  • 01-06-2010 5:32 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beocenter 2600 Speaker Problem
    Hi Tom,
    - and welcome to Beoworld !
    The Beocenter 2600 is not one we hear about everyday here but it's a nice one.
    - First, try swapping the speakers to confirm if the problem is indeed with
    the Beocenter and not one of the speakers or a speaker plug/lead.
    - Next (if the problem is indeed with the Beocenter), move the speakers
    from set 1 to set 2 (or vice versa) and try again.
    - Still a problem ? Try activating the row of push-buttons 10-20 times each. Even
    the ones that has no obvious relation to what's playing at the moment.
    - Then the sound control sliders.
    Let's hear the results.
  • 01-08-2010 11:14 AM In reply to
    • lztom
    • Not Ranked
    • Posts 2
    Hi Martin,
    Thanks for the advice, it worked and the system is operating perfectly again. Much appreciated!
    All the best,
    Tom.
