Latest post 06-17-2007 1:44 AM by ridax. 3 replies.
Page 1 of 1 (4 items)
  • 06-16-2007 2:25 PM
    • zpalmc
    • Not Ranked
    • Joined on 06-10-2007
    • Posts 2
    • Silver Member
    Beolab Penta 2 Display failure on one speaker
     Does anyone have any experience in repairing the Beolab Penta 2 display. One speaker is OK, the other is no display at all.
     I have checked Audio and Video switches and switched round the powerlink cables. Still one speaker refuses to display.
     Also does anyone know where replacement display perspex covers can be found as I have a big crack in one.
    Cheers
    Chris (ZPALMC)
    l
  • 06-16-2007 2:37 PM In reply to
    • Jandyt
    • Top 10 Contributor
    • Joined on 04-01-2007
    • Clitheroe, Lancashire, UK
    • Posts 13,004
    Re: Beolab Penta 2 Display failure on one speaker
    Ridax is the man! Try searching for him then send him a PM
    Good luck.
    Andy T.
    Poor me, never win owt!
  • 06-16-2007 7:12 PM In reply to
    • zpalmc
    • Not Ranked
    • Posts 2
    • Silver Member
    Thanks Andy, I will give it a try.
    Cheers
  • 06-17-2007 1:44 AM In reply to
    • ridax
    • Not Ranked
    • Joined on 04-16-2007
    • Posts 44
    Did you try to switch the display modules between the speakers and see if the fault transfers to the other speaker?  If you by this can make sure that it is the display modue that is faulty and not something in the amplifier section, then try to switch the different boards in the display module to see which board in the display module is faulty.
