Latest post 06-18-2007 6:07 AM by Peter. 3 replies.
Page 1 of 1 (4 items)
  • 06-16-2007 10:09 AM
    • Soren
    • Not Ranked
    • Joined on 05-04-2007
    • Kolding Denmark
    • Posts 56
    beovision 6 front on Beocenter 6
    Hi
     Is it possible to mount A Beovision 6 26" lautspeaker front on the new Beocenter 6?
    Søren
    Filed under: ,
  • 06-16-2007 5:16 PM In reply to
    Re: beovision 6 front on Beocenter 6
    The fixings would appear to differ but I dare say the judicious use of some double sided tape could do it. You will need to check the height and width of the cover as well as I am not convinced they are the same size. You could of course cover the BC6 fret with material.
  • 06-18-2007 5:50 AM In reply to
    I asked about this at my dealer some time ago as I would like to fit a beocenter 6 grill to my beovision 6 (the cloth goes dirty to easily I think). He told me the mechanism on the BC6 was a sliding one as opposied to de BV6 where you push the grill on.
  • 06-18-2007 6:07 AM In reply to
    Completely correct - hence the double sided tape suggestion.
