Latest post 12-30-2009 2:10 PM by StephenPearce. 2 replies.
Page 1 of 1 (3 items)
  • 12-29-2009 11:00 AM
    Moving Beolab 6000 speakers
    I would like to re-position one of my Beolab 6000 speakers and to do so means making the speaker cable longer, by approximately 12 metres. I am assuming I can simply plug in an extension speaker cable with the suitable male & female din plugs on either end?? The existing cable currently goes into the loft to a control panel and it would be quite a work up, especially in the winter to replace the cable completely from the box. I didn't want to lose any of the sound quality......Can anyone offer any views on this??
    Cheers, StephenWhistle
    PS Wishing all members a Very Happy New Year!
  • 12-29-2009 3:17 PM In reply to
    Re: Moving Beolab 6000 speakers
    Your dealer can supply a 8 pin DIN joiner and another length of powerlink cable. No discernable change in sound quality, in my opinion.
    Alternatively try Steve at Sounds Heavenly who advertise at the bottom of this page and who may have other ideas.
    Regards Graham
  • 12-30-2009 2:10 PM In reply to
    Thanks for that Graham, I've now ordered the cables from Steve at Sounds Heavenly!Idea
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
