All,
I have a problem when I am trying to put in channel logos on the Beo5. When I build the layout everything is fine but when I want to download the new layout into the Beo5, it starts but after 30-60 sec it says write timeout and stops. After this the Beo5 works fine but it has not received any changes from the new layout ?
Also, I have downloaded some logos from www.Lyng-sat.com which I would like to use on the Beo5 in .bmp format. I place them in the directory of the images/logos/channel/TV like the other logos, but for some reason they do not show up in the beo5 software ? I think it has something to do with the .xml file, but I have no clue.
Can anyone help me ?
Thanks.
P.S. I run beo5 software 3.23 and I only try to put in around 20 logos.
