Latest post 12-29-2009 10:57 AM by mjmedlo. 4 replies.
Page 1 of 1 (5 items)
  • 12-28-2009 3:10 PM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    Help with XML generator please
    I found this code for one of my products.
    0000 006D 0022 0002 0157 00AC 0015 0016 0015 0016 0015 0041 0015 0016 0015 0016 0015 0016 0015 0016 0015 0016 0015 0041 0015 0041 0015 0016 0015 0041 0015 0041 0015 0041 0015 0041 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0016 0015 0041 0015 0041 0015 0689 0157 0056 0015 0E94
    It's supposed to be an "ON" button. .
    Can someone help?
    I have the XML generator program and the configuration tool. .
    MJM
    I'm ready for something new that I actually want to buy!
  • 12-28-2009 3:39 PM In reply to
    Re: Help with XML generator please
    I followed the instructions here and everything worked fine.
    Cheers,
    Frank
  • 12-28-2009 6:37 PM In reply to
    • BOMF
    • Not Ranked
    • Joined on 12-12-2009
    • Lausanne
    • Posts 26
    I have just downloaded the last version of the Lintronic software (v2.0.5.3) but the user interface is quiet different from the screen captures shown in this tutorial.
    I tried to paste some Pronto codes in the converter but the "Convert" button is still inactive... maybe because there is no Lintronic hardware connected to my PC... is this a kind of protection from Lintronic ?
    Regards,
    BOMF
  • 12-29-2009 7:23 AM In reply to
    • Weebyx
    • Top 200 Contributor
    • Joined on 06-30-2008
    • Denmark
    • Posts 321
    Try to create an XML file with the following code, and put in your "Beo5 Configuration Tool\ThirdParties" directory. Then add the product using the config tool.
    <?xml version='1.0' encoding='utf-8'?>
     <root stVersion='1.0'>
      <resource><image stName='NonBO' stFile='images\NonBO.BMP'/></resource>
       <product stName='SomeThing' stCaption='SomeThing' stMenuCaption='SomeThing' stImage='NonBO' stProductType='accessories3Party' stScreenType='1'>
        <source_item stName='Some' stCaption='Some' stScreenType='0' stMenuCaption='Some' stSourceType='accessories3Party' nPreferedRow='4' nPriority='1' nPreferedColumn='1' nPage='1' nX='0' nY='95' nWidth='213' nHeight='25' nRowFinal='4' nColumnFinal='0'>
         <source_subItem stName='Some\POWERON' stCaption='POWERON' stMenuCaption='POWERON' stScreenType='0' stIR='RAW:GlobalManual=1#ListOfFlanks=$22D6,$1178,$0222,$023C,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$023C,$0222,$023C,$0222,$023C,$0222,$023C,$0222,$069A,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$069A,$0222,$069A,$0222,$069A,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$023C,$0222,$069A,$0222,$069A,$0222,$A9EA,$22D6,$08BC,$0222,$17B08#IRSEQUENCE=RAW#Carrier=38028#Pause1=65000#Pause2=65000#Comment=RAW FlankList: 50 flanks' stLeave='Rel 1' stIRVideoOp1='F0:TV:' stIRVideoOp2='F0:TV:' stIRVideoOp4='L_F0:TV:' stIRVideoOp5='F0:TV:' stIRVideoOp6='F0:TV:' stIRAudioOp1='F0:RADIO:' stIRAudioOp2='F0:TV:' stIRAudioOp4='L_F0:TV:' stIRAudioOp5='F0:RADIO:' stIRAudioOp6='F0:TV:' stIRVideoOp5Link='L_F0:TV:' stIRVideoOp6Link='L_F0:TV:' stIRAudioOp5Link='L_F0:RADIO:' stIRAudioOp6Link='L_F0:TV:' stIRVideoOp2Av='F0:RADIO:' stIRVideoOp4Av='L_F0:RADIO:' stIRVideoOp6Av='F0:RADIO:' stIRVideoOp6AvLink='L_F0:RADIO:' nPage='1' nX='0' nY='20' nWidth='213' nHeight='25' nRowFinal='1' nColumnFinal='0'/>
      </source_item>
       </product>
     </root>
    This should be the on button for your product.
    /Weebyx
  • 12-29-2009 10:57 AM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    I got the same result in the XML generator.
    Do i just copy and paste the result in to the BEO5 config folders?
    Also, I assume I need to do this for every button I want?
    Thanks again for the help
    MJM
