Hi all!
Is it possible to have for example an audio source connected to a Beovision 8-40 (V.AUX) and then distribute it to a BeoLink Active?
Or does this require an AudioMaster or a B&O linkroom TV?
should work.
I have an iPod Touch on V.aux2 and this can be distributed over ML. The iPod is connected via Apple Composite Cable.
BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 / Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
and you don't have any AudioMaster connected in the masterlink?
I had a BV 8-40 for test and I just tried the built in DVB-C from a BeoLink Active. It activated the speakers and then turned them off?
