1st March February 2012
Latest post 06-17-2007 12:15 AM by Corvin. 15 replies.
06-15-2007 8:57 AM
Corvin
- Joined on 04-16-2007
- Australia
- Posts 124
I am just watching a movie and noticed one of the front chanels not working. One of my BL5's has no indicator light at all, i disconnected power for about 5 minuites and still nothing. It just acts as though it is not plugged in. Any ideas as to the problem anyone. (of course i have checked the power outlet!)
Corvin
- Australia
- Posts 124
Ahh I see Alex is back, hope all your exams went well. As for the fuse in the plug???? Sorry foreign to me here in OZ, unless I have my head in the sand. Is there a fuse in the speaker?
Corvin
- Australia
- Posts 124
I appreciate the help, but power to the speaker is via a simple 2 core lead from the socket. not much can go wrong here, Can not see any reference to a fuse in the guide. Not very happy at the moment though.
Alex
- Bath & Cardiff, UK
- Posts 2,990
Corvin:I appreciate the help, but power to the speaker is via a simple 2 core lead from the socket. not much can go wrong here, Can not see any reference to a fuse in the guide. Not very happy at the moment though.
Still worth swapping the speakers round! As you say, very little can go wrong in a cable, which is why generally they are overlooked. It is most likely the speaker, but it would be worth just swapping them round to check. Each speaker can draw quite a bit over 2500 watts from a power socket and seeing as a socket goes up to 3000 watts, if one is poorly wired, there is always the potential of something burning through. However unlikely, it's worth a try!
Weekly top artists:
Corvin
- Australia
- Posts 124
Thanks all, sorry Peter i was posting a reply as you were so the fuse in the speaker question apears before my question. 00:16 now so i'm off to bed, thanks all, think i may try the dealer.
Page 1 of 1 (16 items)
