Latest post 03-01-2008 7:11 PM by apetley. 11 replies.
Page 1 of 1 (12 items)
  • 06-15-2007 8:47 AM
    Beomaster 1001 indicator lamps
    I have now replaced my redundant beomaster 1001 with another one.
    It works perfectly ok but most of the indicator lamps no longer work and I wish to replace them all
    to restore the unit to its original glory. I intend to do the job myself using the service manual so
    does anyone know if the lamps are very easy to get hold of in retail electronic stores
    such as maplins. Better still could they by replaced with LED's?
  • 06-15-2007 4:37 PM In reply to
    Re: Beomaster 1001 indicator lamps
    Martin (ie Dillen) ought to be able to supply the correct ones. I got a set for my 2000 (the old one) and they were just the job - even had a tiddly one that fitted inside the glass shell of the lamp that was glued in!
    Steve
  • 06-16-2007 6:58 AM In reply to
    Thanks for that.
    I now also find that i can't get stereo broadcast on the fm receive even through a roof VHF aerial. If the FM stereo indicator lamp is not working could this be the caurs of this problem on old receivers.  The mono button is not pressed down.
  • 06-16-2007 8:33 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    I wouldn't mount LED's, the circuit wasn't built for it.
    F.e. a LED will not be able to indicate the signal strength as the lamp does without eventual modification of the circuit.
    I have correct lamps in stock if you can't find any locally.
  • 06-16-2007 8:56 AM In reply to
    I assume from this you can receive FM, just not in stereo? I wouldn't have expected the lamp alone to have made this difference - it didn't on either of my 1000's, anyway. Does this bit of your other 1001 work okay?
    Steve
  • 06-16-2007 11:25 AM In reply to
    Yes the stereo broadcast and the lamp works ok with some radio stations on my other unit. However it's in a diferent location where reception is very good and i'm on the top floor.
    I will be relocating my newer unit to the same place in a few days and then i do intend to try it there and see what happens.
  • 06-16-2007 11:38 AM In reply to
    Thanks for that.
    The 1001 service manual I downloaded is a little unclear to me,  are the lamps easy to fit once the area is reached?  Do they plug strait in or will i need soldering skills?
  • 06-16-2007 2:40 PM In reply to
    • Dillen
    • Posts 5,008
    The lamps are of the push-fit socket type. If the wires are still good you won't need any soldering.
  • 06-16-2007 3:43 PM In reply to
    Thanks Martin. That's a great help.
  • 02-09-2008 2:05 PM In reply to
    hi there,
    I have recently joined beoworld and was intriqued to see you have light bulbs for a beomaster 1001 - do you still have some as all 4 of mine are dead?
    Andrew
    andrew@p*****.demon.co.uk
  • 02-10-2008 6:31 AM In reply to
    • Dillen
    • Posts 5,008
    Andrew,
    Welcome to Beoworld and thanks for joining as a gold member !
    Yes, I have the lamps and you have email !
    (email address partly removed to prevent spam)
  • 03-01-2008 7:11 PM In reply to
    lamps recieved with a suitable glow of appreciation, many thanks
