Latest post 12-18-2009 3:57 AM by guffas. 3 replies.
Page 1 of 1 (4 items)
  • 12-17-2009 9:44 AM
    • mjmedlo
    • Top 150 Contributor
    • Joined on 06-07-2008
    • Arkansas, USA
    • Posts 384
    transfer a beo5 setup from one computer to the next. . .
    How do you do this?
    I thought you could copy the xml file and load it in. . didn't work. .
    Help please.
    MJM
    I'm ready for something new that I actually want to buy!
  • 12-17-2009 1:45 PM In reply to
    • YannChris
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Larmor-Plage, France
    • Posts 276
    Re: transfer a beo5 setup from one computer to the next. . .
    Hello,
    Just transfer the "clients" directory from the old comptuer to the new one (once you've installed the configuration tool).
    Yann.
    Ne pas s'en faire et boire frais!
    Mon install en images: cliquez sur mon profil, au dessus de mon avatar - Puis "My files" tout en bas.
    Pictures of my setup: click on my nickname, above my avatar. Then "my files" at the bottom of the page.
  • 12-17-2009 8:35 PM In reply to
    • mjmedlo
    • Arkansas, USA
    • Posts 384
    got it!
    thanks
    MJM
  • 12-18-2009 3:57 AM In reply to
    Alternatively, you can right click on the configuration at the Welcome tab, and then select Export. This also includes any custom logos and graphics that may not be present on the other computer.
    To import the configuration, just click on Import and browse to the CTX file.
    Actually you can export and share logo templates and buttons the same way.
