Latest post 06-19-2007 2:04 AM by Medogsfat. 6 replies.
Page 1 of 1 (7 items)
  • 06-15-2007 5:20 AM
    Wall mounts for CX100's
    Can I just use a universal mount?? If not, where would I get a set??
    THanks,
  • 06-17-2007 9:50 PM In reply to
    • BandOkie
    • Top 500 Contributor
    • Joined on 04-16-2007
    • Owasso, Oklahoma - USA
    • Posts 112
    Re: Wall mounts for CX100's
    I don't know if you can use a universal mount.  I have a pair, if you need them.  They may still be available from B&O also.  Let me know if you need a pair.
    Michael
    m.l.williams@cox.net
    BandOkie
    Michael in Oklahoma
  • 06-18-2007 2:14 AM In reply to
    THanks, I'm trying to put togther a BnO home theatre and I need to mount one center speaker horizontal. How much would you take for them?
    THanks again for the reply.
  • 06-18-2007 9:14 AM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    The CX wall brackets won't allow you to mount them horzontally as they are nothing more than a hook that fits in the hole in the back.
    Chris.
  • 06-18-2007 10:51 AM In reply to
    Thanks Chris,
     So..can the CX100's be mounted horizontal???
    Thanks again..K
  • 06-18-2007 4:57 PM In reply to
    • BandOkie
    • Posts 112
    Ya, what he said.  I have not seen anything made to mount them horizontally.  It would need to be just a shelf.  The back of the speaker does not have much to mount to.
    Michael
    BandOkie
    Michael in Oklahoma
  • 06-19-2007 2:04 AM In reply to
    • Medogsfat
    • Posts 4,045
    Michael's correct, the only real way would be to mount them on some sort of shelf.
    Chris.
