When connecting a Blu Ray player to a BV 10 (or other similar TV I expect), is there any benefit in connecting the digital audio output in addition to HDMI or will the HDMI do the lot to the same standard?
S
BV10 - BL9 - BL6000 - BL2 - BS9000 - BL4000 - BL3500 - BL2000 - PC2 - BL4000 - B-Passive x 3 - BV1 - BS3000 - BL4
Just connect the HDMI. Adding the digital audio out is of no use for "normal use"
There was a problem with PCM 2.0 decoding with the BV7, which is resolved by connecting HDMI+ analog audio, but this doesn't happen with BV10.
www.diisign.com
