Latest post 12-14-2009 8:24 AM by EOB. 2 replies.
Page 1 of 1 (3 items)
  • 12-11-2009 8:03 AM
    • EOB
    • Top 500 Contributor
    • Joined on 04-18-2007
    • Posts 188
    Beo1 question
    *1- Setting a BC1 -2001 with original Beo1 remote and recently a second hand Beo4 remote. Both working fine on the system
    *2- Setting a BC1 -2004 with original Beo4 remote.
    Took the Beo1 to be used on the BC1 -2004. But the Beo1 isnt working om the BC1-2004 ?
    Is it possible to get it to work on the BC1 -2004 ?
  • 12-11-2009 2:37 PM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    Re: Beo1 question
    Maybe you want to try this:
    http://forum.beoworld.org/forums/t/29071.aspx?PageIndex=1
    Stefan
  • 12-14-2009 8:24 AM In reply to
    • EOB
    • Posts 188
    Re: Beo1 question
    Thank you Stefan for the redirection.
    Yes -  thumbs up
