Latest post 12-10-2009 7:56 AM by Peter. 1 replies.
Page 1 of 1 (2 items)
  • 12-10-2009 6:22 AM
    • samuk
    • Not Ranked
    • Joined on 01-31-2009
    • Posts 15
    7 pin din socket
    Hello all
    My loved  CD6500 giving trouble. So I have got a another cd player to conncet my Amplifier.
    I did check with Maplins they said that they do not sell 7 pin din socket but sells 5 pin one. Is that will work with my new cd player
    Thanks,
    Kind Regds,
    Samuk
  • 12-10-2009 7:56 AM In reply to
    Re: 7 pin din socket
    Yes. The two extra pins are for datalink which your new CD player will not have so is not needed. what is wrong with your 6500 though? It is likely that you have been told that the laser has blown or needs replacing. It is much more likely that there is simply a capacitor or two on the laser control board that needs replacing - cheap!
