Latest post 12-09-2009 11:13 AM by markiedee. 4 replies.
Page 1 of 1 (5 items)
  • 12-09-2009 6:20 AM
    AppleTV connected to a BV7-55
    On Monday, I became the lucky owner of the first BV7-55 in Germany - I got to tell you that the picture on that TV through a SKY HD box is just incredible. Yesterday, watching the final rounds of the group stages in Champions League in HD was like being present at the stadiums .
    However, I have my AppleTV connected through the PUC (Apple Remote) and it works very well except when I turn off my system. In the TV the AppleTV is set-up to go on standby with the system, but nothing happens when I switch off the system ?
    Does anybody have similar issue and a workaround for it or is it a known bug ?
  • 12-09-2009 7:12 AM In reply to
    Re: AppleTV connected to a BV7-55
    congratulations trolle i'm unable to help you out with the apple tv situation that your having but would be most grateful if you posted a picture of your bv7-55 to get an idea of what it looks like in a home enviroment.
    i can only envy you on what must be a cinematic experience that you must be having.
  • 12-09-2009 8:06 AM In reply to
    I have the same problem with our BV7 MKIII and Apple TV. I have the additional problem that even if Apple TV is in stand by, turning another source on or off turns the Apple TV back on. My solution was to assign a different device to the Apple TV in the menu. Then use the remote learning function of the Apple TV to learn those commands. It now turns on only when I want it to. To turn it to standby I use the Apple TV settings menu.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 12-09-2009 10:41 AM In reply to
    markiedee:
    I will for sure do so when it is probably setup (very soon).
    But I can confirm that the Cinematic experience is very real and the sound is perfect (kept my BL7-4 from my BV7-40).
  • 12-09-2009 11:13 AM In reply to
    thanks for replying and looking forward to your pictures and enjoy your new tv.
