Hoi Nitro2,
Ooit heb ik de volgende nadelen gelezen van de 1.3 software.
Groet, Robert
A service software, version 1.3, for Beomaster 7000 has now been released. The service software makes it possible to use Beolink 7000 to operate Beosystem 7000 in a set-up with BeoVision Avant.
Impossible operation via Beolink 7000:
Timer light programming.
NOTE!
*Timer play programming, Timer on/off as well as Sound adjustment (e.g. balance, bass, etc.) is made via Avant using the Beo4.
*After installation and option programming or after mains drop-out, an audio source must be selected by hands-on operation to obtain the correct A/V set-up. This influences e.g. A/V RECORD.
*When timer programming the audio master, the Timer ON/OFF on the audio master must be set to OFF. The Timer ON/OFF function is set on the TV.
*Audio sources are not switched off when changing to video source (because of possible users in link rooms).
*Balance, Bass, Treble and Loudness cannot be adjusted on the audio master, operation is made with a remote control via Avant. Adjustment will, however, affect a possible Link room. Volume adjusted from the audio master, adjusts audio sources, but display indication on the audio master may not be correct.
*Hands-on operation of audio recording of video sources is not possible (a remote control must be used).
*Recording on a possible A.TAPE 2 cannot be made by means of a remote control.
*Audio Timer record from program no. with 3 digits, e.g. the Satellite receiver in BeoVision Avant is not possible.
*In some cases it may be necessary to press stand by for several seconds to switch off a product.
Part no. for service software 1.3 (pos. 4IC2, coordinate 5A) is: 8342830.
