Can anyone advise how you can tell what version of BS 3 you are running.?
Thank you.
Do you mean "type number"? In that case 2720.
-Andreas
BLab5, BLab5000, BLab8000, BV10, BS9000, BS3, Beo5, Beo4, BLink1000, BLink5000, BLink7000, A2, A8, Form2
Andreas,
I was meaning the version number. It was my understanding that there were changes to BV3 since it's introduction, just wondering if there was anyway to tell what version I have.
regards
Keith
If the device has changed then wouldn't the type number change as well?
Evan
As others have stated there are different type numbers which relate to different countries normally.
In the case of the Beosystem 3 there has been two versions:-
The latest TV software version is 7.05
Regards Keith....
Thank you Keith
