HI GUYS
I INSTALLED A BEOSOUND 5 FOR A CUSTOMER THE OTHER DAY, WITH A WINDOWS LAPTOP, EVERYTHING WAS WORKING OK, HOW EVER I WAS OUT TODAY FINISHING THE JOB ONLY TO BE TOLD THAT HE HAS A NEW IMAC (21") i DELETED THE SOFTWARE ON THE LAPTOP PUT BEOCONNECT ON THE MAC AND GOT IT UP AND RUNNING, MY QUESTION IS THIS, IS IT A SIMPLE CASE OF JUST SELECT WHAT YOU WANT FROM ITUNES AND THEN DRAG IT OVER THE B&O ICON, WILL THIS TRANSFER THE MUSIC?? THE OTHER QUESTION IS IF YOU ARE USING ITUNES, CAN YOU USE ITOUCH AS REMOTE TO SEE THE ALBUMS AND THEN SELECT WHAT YOU LIKE AND IT WILL THEN PLAY THROUGH THE LINK SPEAKERS, IN THIS CASE CUSTOMER HAS TWO LAB3500. I HAVE USED THE FUCTION ON WINDOWS PCS AN KNOW HOW TO RIP CD'S SET UP PLAYLISTS, BUT I DID NOT SEE ANY INSTRUCTIONS FOR A MAC. I ASK THE QUESTION ON HERE AS I FEEL BANG & OLUFSEN TECHNICAL UK DO NOT KNOW THE ANSWER, BRING BACK THE OLD DAYS WHEN YOU COULD SPEAK TO SOMEBODY THAT KNEW THE PRODUCT INSIDE AND OUT. THANKS IN ADVANCE FOR ANY HELP
