Latest post 12-05-2009 2:34 PM by jk1002. 1 replies.
Page 1 of 1 (2 items)
  • 11-26-2009 4:45 PM
    • jfoot
    • Not Ranked
    • Joined on 11-26-2009
    • Posts 1
    USB Drive Play Out Solution for BeoSound 2000
    Just ordered Beatles USB for the higher quality audio flac files.  Need a solution please as to best way to maintain playback quality through BeoSound 2000 system, which has no USB interface.  What would be the best way to play out these files through the 2000?  Thanks.
  • 12-05-2009 2:34 PM In reply to
    Re: USB Drive Play Out Solution for BeoSound 2000
    In my opinion the sound quality of the BS2000 doesn't warrant to jump through hoops. I would look at connecting an Ipod or Airport Express or something like this.
    If you have an Iphone or Ipod touch  I would like to recommend Apple TV. I also like the Sonos system conceptional even though the design is clunky.
    You can convert the FLAC files into something high quality if the MP3s included are not good enough , are you on PC or Mac?
