Latest post 11-25-2009 8:53 AM by Dillen. 1 replies.
Page 1 of 1 (2 items)
  • 11-25-2009 8:21 AM
    Beomaster 1900-2 Balance Indicator Issue
    Hi to all,
    as you can see, i'm new to this. Great forums!
    I recently bought a Beomaster 1900-2. Sometime dreams come true after a long, long time Big Smile!
    But, i got a little issue with my new treasure. Maybe someone can give a hint, what may cause this:
    After some time the balance indicatior dims its light. If you switch off and wait a little it will get get to normal brightness. Only the balance indicator is affected, all other lights are working perfectly. The time to dim varies and sometimes even nothing happens. I Got the impression, but i'm not really sure, this depends on the choosen fm-preset.
    Anyone got an idea? Should I change the bulbs? What can cause this behaviour?
    Thanks in advance for any help ....
    Carsten.
  • 11-25-2009 8:53 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 1900-2 Balance Indicator Issue
    Carsten,
    Welcome to Beoworld !
    If it's only the balance indicator, I suppose it will be the bulb itself or its solder joints.
