Latest post 11-23-2009 10:39 AM by Uldall`s. 2 replies.
Page 1 of 1 (3 items)
  • 11-22-2009 11:13 AM
    Avabt 32 dvd
    Hello out there. sitting in the evening and enjoy a DVD, but suddenly stops the DVD around the mid-term ....
    I immediately contact my Bang and Olufsen dealership and being told I should try cleaning the lens.
    I have tried without luck ... ¨
    anyone out there who have had similar problems with their Avant ...??
    My avant is from 2006 and have never had problems, however, seen countless dvds ...
    Maybe it is just wear ...??
    / Uldall
    Beosound century Beocenter2 Beolab2 Beolab3 Beolab8000 Beolab6000Black Beolab4000 Beovision Avant 32 DVD RF MX7000ML MX4200ML MX1500 Beolink1000 Beo1 Beo4 Beo5 Beosound1 Beosound6 Beocom2 Beocom6000 Serene BeoPort A4 A8 A9 LC1 LC2 Kabinet 2168 Black line FORM1 Beotime Beotruck.
  • 11-23-2009 6:18 AM In reply to
    Re: Avabt 32 dvd
    Hi there,
    It might be worth checking if it's the DVD's fault, maybe try another disc? And then the same disc on your PC?
  • 11-23-2009 10:39 AM In reply to
    Re: Avabt 32 dvd
    Hi solved the problem requires a new DVD work ..
    /Uldall
