Latest post 11-22-2009 4:42 AM by PH. 12 replies.
Page 1 of 1 (13 items)
  • 11-19-2009 9:28 AM
    • PH
    • Not Ranked
    • Joined on 11-19-2009
    • Posts 16
    Beo5 programming
    Hi. I need to program Beo5 as below.
    This is from Link1000 and works. (Is my garden light control :-) )
    LINK
    LIGHT
    GOTO
    9
    1
    This will activate lamp1 in my garden, but i cant fint "LINK" in the Beo5 programming tools.
    Do someone know how ??
    I have uses this command in IR.
    1:000:LIGHT:LIGHT
    1:000:ALL:CIFFER_9
    1:000:ALL:CIFFER_1
    And it works great, but i will switch on my Radio in the main room. But if I use Beolink1000 as decribed, all is OK. So i need
    to find the "LINK" programming metode.
    Hope for some help.
    PH
  • 11-19-2009 9:40 AM In reply to
    Re: Beo5 programming
    If you want to activate lamp 1, the sequence should normally be:
    LIGHT GOTO 1 PLAY
    or LIGHT (LIST) LAMP 1 GO with the Beo4.
    I do not have the Config program here as I am at work now, but make sure you send the numbers to the LC2 rather than to the hifi/tv.
    To do so send:
    1:000:LIGHT:CIFFER_1     (instead of ALL).
    P.
  • 11-19-2009 10:22 AM In reply to
    • stefan
    • Top 50 Contributor
    • Joined on 04-16-2007
    • 200 miles from Struer
    • Posts 1,733
    You have found the LINK mode by selecting "1" in the sequence:
    1:000:LIGHT:LIGHT
    1:000:ALL:CIFFER_9
    1:000:ALL:CIFFER_1
    But I can`t believe that this macro works, because there is no LIGHT scene 91 and no LAMP no. 91.....(!?)
    And, as Phil said, you have to use LIGHT mode, not "ALL".
    Stefan
  • 11-19-2009 11:11 AM In reply to
    • PH
    • Not Ranked
    • Posts 16
    Hi all, and thanks for reply.
    I have buildt my "OWN" Garden light, therefor I use "9" for light, so I do not conflict to B&O orginal Light system.
    Therefore I use this command from Link1000
    LINK
    LIGHT
    GOTO
    9
    1
    And it turn ON my Garden light. ( I is 10 years age I buildt it), but again the "LINK" and can't find. I use the first "1" for link, and it works
    in all other room that the main room, here it start Radio and garden light with Beo5, but with Link 1000 only Garden ligt starts.
    Thank a lot
    Br
    PH
  • 11-19-2009 1:55 PM In reply to
    I do not think it is possible to create such a link button.
    I just tried to make such a button so that I could turn on the light in the leving room from my bedroom. But no
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 11-19-2009 4:58 PM In reply to
    • stefan
    • Posts 1,733
    Try:
    1:000:LIGHT:GOTO
    1:000:LIGHT:CIFFER_9
    Maybe you will need to insert a delay between the single commands.
    @Tillquist:
    Yes, it is possible to use LINK LIGHT commands. It works via an MCL system with 2 way devices like BS 7000 and MCL2a....
    (and maybe via Masterlink gateway, but who knows....(??)
    Stefan
  • 11-20-2009 10:05 AM In reply to
    Hmm, I can not get it to work with Master Link.
    I have BeoVision 7-40 mk.III and BeoCenter 2 mk.III in the living room and LC2 and then I BeoLab 3500 in the bedroom.
    But I can not turn on the light in the living  room when I'm in the bedroom from Beo 5, only with BeoLink 1000
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 11-20-2009 11:22 AM In reply to
    • stefan
    • Posts 1,733
    You can control your LC2 in the livingroom from the bedroom...??...via BL3500 and Masterlink ...???
    How can this work...?????
    Stefan
  • 11-20-2009 11:43 AM In reply to
    Sorry, I think I was in dreamland. Unsure
    I just tested it with BeoLink 1000 and as you know you can not manage LC2 from another room than the LC2 is located in. Sad
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 11-20-2009 3:47 PM In reply to
    • stefan
    • Posts 1,733
    Tillquist:
    Sorry, I think I was in dreamland. Unsure.......
    So did I  ...
    Stefan
  • 11-21-2009 3:02 AM In reply to
    • PH
    • Not Ranked
    • Posts 16
    Hi all, and thank for helping. I will try some combinations later. It is not a LC2, but a homemade controller I have buildt many Years ago.
    I has been working OK with Beolink 1000 and Beo 4, but I have to use the command. Link Light 9 and then 1 for lamp1 2 for lamp 2 etc.
    With Beo4 I use same commands, and it works OK. With Beo5 I have tried severals combinations, but my Radio (Overture 3000) switch on at the same time. fx. if I use LINK LIGHT 9 2, the radio switch on channel 2, or if TV (BV7-40) is ON, it switch to channel 2.
    But nevermind. I will go to my office and use my "old" Beomaster 9500, and there use Beo5, it works OK, and so it will be until later.
    By the way: Is it possibel to add a Zone in one already working Beo5 ? I have tried, but the zone will not be shown.
    Thank and have a nice day.
    Br PH
  • 11-22-2009 4:39 AM In reply to
    • PH
    • Not Ranked
    • Posts 16
    Hi allSmile
    I have out now, and its working
  • 11-22-2009 4:42 AM In reply to
    • PH
    • Not Ranked
    • Posts 16
    Hi again, sorry but here are ny solution, and it works ;O)
    Beo5 Commands.
    1:000:LIGHT:LIGHT
    Delay:50ms
    1:000:LIGHT:GOTO
    Delay:50ms
    Delay:50ms
    It works, and do not conflict with radio /DTV
    Have a nice day
    BR
    PHYes -  thumbs up
