Latest post 12-09-2009 1:56 PM by Tillquist. 8 replies.
Page 1 of 1 (9 items)
  • 11-18-2009 12:48 PM
    PUC XML for Samsung BD-P3600
    I want to hear there are some who have XML to a Samsung BD-P3600. In Beo5 CT is only a Samsung BD-P1200 can be chosen.
    Has Samsung BD-P1200 the same functions as I need to control the Samsung BD-P3600 Blu-ray?
    My Bang & Olufsen....
    • BeoCenter 2 DAB/DVD mk.II
    • BeoVision 7-40 DVD mk.III
    • BeoLab Penta mk.III
    • BeoLab 4000 icepower
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beo 4 mk.I & mk.III
    • Beocom 6000
    • A8 Earphones
  • 11-18-2009 1:29 PM In reply to
    Re: PUC XML for Samsung BD-P3600
    As you say the PUC does not have the BD-3600 but it does have the BD-4600 and I can confirm that both units use the same protocol and carrier frequency and teh commands available in each can be seen in the screen shots below. The first shot is for the BD-1200
    Regards Keith....
  • 11-18-2009 2:06 PM In reply to
    Can I get the XML for BD-P4600, for I don't have it in my Beo5 CT3.23 ?
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 11-18-2009 2:50 PM In reply to
    Click HERE to download
    Regards Keith....
  • 11-18-2009 3:05 PM In reply to
    Thanks, Keith Smile
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 11-22-2009 9:55 AM In reply to
    Hi Keith
    Are you 100% sure that the PUC BD-P4600 can control the BD-P3600!
    For I will not order a Samsung BD-P3600 if the PUC in BeoVision 7-40 can't crontrol it.
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 11-22-2009 2:17 PM In reply to
    I did not say that I am 100% sure that the PUC for the BD-P4600 can control the BD-P3600.
    What I said and showed was that the earlier P1200 and the P3600 use the same protocol, carrier frequency and almost the same commands, so it is reasonable to assume the P3600 does as well. It is unlikely (but not impossible) that a manufacturer would change the remote and receiver in a earlier product to something different and then change it back again.
    Generally speaking unless a later product has many different commands than an earlier version then they tend to use the same protocol etc as the earlier version
    Regards Keith....
  • 11-22-2009 3:05 PM In reply to
    Thanks Smile
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
  • 12-09-2009 1:56 PM In reply to
    I've been tested it.
    And I can tell the PUC BD-P4600 can control a BD-P3600 fully.
    • BeoLab 4000
    • BeoLab 3500
    • Beo 5
    • Beocom 6000
    • A8 Earphones
