BEO5 Error message.....
16 November 2009 - 15:04:01
Source : AtiDriverUSBBeo5
Method : System.Object ForwardCallToInvokeMember(System.String, System.Reflection.BindingFlags, System.Object, Int32
, System.Runtime.Remoting.Proxies.MessageData ByRef)
Message : Bad configuration file
Trace : at System.RuntimeType.ForwardCallToInvokeMember(String memberName, BindingFlags flags, Object target, Int32
aWrapperTypes, MessageData& msgData) at AtiDriverUSBBeo5Lib._DAtiDriverUSB.SendConfiguration(String fileName) at AxAtiDriverUSBBeo5Lib.AxAtiDriverUSB.SendConfiguration(String fileName) at Beo5_Config_Tool.Tools.ProgressBar.ProgressBarForm2.USBSendNew(Boolean bType, String stFileToSend, String stMessage)
Dear Beo Experts
Have been happily updating my Beo5 with impunity until now. Having upgraded my STB to a Topfield PVR and was in the process of amending/editing the revised channel numbers and shortcuts to menus etc. a relatively simple exercise I had found in the past, this time uploading the revised file to the Beo5 it came back with "Bad Configuration File".
I have repeated the exercise with the same result. I suppose I have to start again, which I could do I suppose, what I am nervous of doing is deleting the profile as I might not be ableto connect again, it would be a chore to start again - but hey ho. Is there anyway I can load an earlier version of my config file which isn't 'bad'?
I was pretty enthusiastic about the beast - hopefully this quirk won't change that
Fingers crossed
Gary
