Hi All,
After recently purchasing a Beovision 7 TV I am now trying to locate the HDMI port so that I can plug in my laptop.
Any help much appreciated.
Regards,
Alex
Is it a mk.I / mk.II / mk.III or mk.IV ?
Don't you get the usermanual with it ?
My Bang & Olufsen....
It may just have a DVI port. You need an adapter.
Thanks Peter, I think this may be the case.
Configure AV4 as the PC connection and you can use a 3.5mm jack to 2 stereo phono leads for PC audio.
