Latest post 11-09-2009 9:14 AM by Keith Saunders. 3 replies.
Page 1 of 1 (4 items)
  • 11-09-2009 7:06 AM
    Beo5 and Humax STB
    I have a Beovision 8-40 and Humax STB. The Beo5 was supplied programmed to control the Humax, my problem is that it is unusable slow often taking 5s+ to respond to commands, is this normal
    Stuart
  • 11-09-2009 7:15 AM In reply to
    Re: Beo5 and Humax STB
    Hello Stuart,
    I am assuming the Humax STB is being controlled via the PUC in the Beovision 8-40 and NOT directly from the Beo5 ?
    If you use the original Humax remote control does it also take 5+ seconds to respond ?
    Regards Keith....
  • 11-09-2009 9:04 AM In reply to
    Yes it is controlled via the PUC and I am using the original Humax remote which works fine
    Stuart
  • 11-09-2009 9:14 AM In reply to
    In that case what you are seeing is almost certainly the inbuilt delay in case you are for example entering several digits of a channel number.
    When you have to press OK (Centre button) press it twice quickly will override the timed period.
    Regards Keith....
