Latest post 11-11-2009 5:09 PM by Bieele. 3 replies.
Page 1 of 1 (4 items)
  • 11-08-2009 3:00 AM
    • Bieele
    • Top 200 Contributor
    • Joined on 04-16-2007
    • Netherlands
    • Posts 339
    sampling frequencies BV8-40
    What sampling frequencies can the BV8-40 handle as inputs from a linear PCM source?
    Linear PCM 2 channels 88.2 MHz
    Linear PCM 2 channels 176.4 MHz
    Linear PCM 2 channels 96 MHz
    Linear PCM 2 channels 192 MHz
    Linear PCM 5.1 channels 44.1 MHz
    Linear PCM 5.1 channels 88.2 MHz
    Linear PCM 5.1 channels 176.4 MHz
    Linear PCM 5.1 channels 48 MHz
    Linear PCM 5.1 channels 96 MHz
    Linear PCM 5.1 channels 192 MHz
    Hope anyone can help!
    Thank you!
    Bieele
    Heej zuij der alles veur gaeve En heej zaet ze mogen ut hebbe van meej
  • 11-09-2009 3:37 PM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    Re: sampling frequencies BV8-40
    Anyone that can help?
  • 11-09-2009 10:45 PM In reply to
    Good question, but beyond my knowledge.
    Beosound 1, 5, 2000, and 3000
    Beotime, Beotalk, Beocoms
  • 11-11-2009 5:09 PM In reply to
    • Bieele
    • Netherlands
    • Posts 339
    One last try to get an answer on this question..... .
    Is the question that difficult? Or is this subject on the 'forbidden topic' list?
    I would really like to get an answer because I would like to set my PS3 up properly, reducing the amount of used audio options seems to reduce the ticking/plopping sound issues.
    Bieele
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
