Latest post 11-01-2009 4:27 PM by beoaus. 2 replies.
Page 1 of 1 (3 items)
  • 11-01-2009 3:07 AM
    • beoaus
    • Top 150 Contributor
    • Joined on 04-16-2007
    • Melbourne, Australia
    • Posts 445
    Outdoor speakers
    Looking for some in roof speakers to service a balcony. Sonance have been recommend but I have not heard them. Any other recommendations?  Its rather exposed and salt air would be a factor. I would connect to a beolink passive.
    Thanks, Beoaus.
  • 11-01-2009 2:09 PM In reply to
    Re: Outdoor speakers
    Hi Beoaus,
    I presume from your name that you are in Australia, if you are looking for true all weather speakers then most of the models are a cabinet/satellite type speaker, if you just want a moisture resistant type then Monitor Audio & Kef in-ceiling & in-walls are suitable for a semi exposed location * both sound pretty good to boot, my leaning would be towards the Monitor Audio as they will compliment the passive very well due to there neutral sound.
    Simon
  • 11-01-2009 4:27 PM In reply to
    • beoaus
    • Posts 445
    Just updated my profile.
    I'll check them both out.  The elements are a consideration causing rusting etc...
    Thanks, beoaus.
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
