Latest post 10-28-2009 6:47 AM by tournedos. 1 replies.
Page 1 of 1 (2 items)
  • 10-27-2009 7:08 PM
    • beoNH
    • Not Ranked
    • Joined on 10-20-2009
    • Posts 3
    buzzing, beogram 3404 after prolonged use
    can't figure this one out...
    after a certain amount of time (maybe 3/4 through a record), i am getting a slight buzz through both speakers.  it will continue after the record stops.  if i switch to "tape" or  tuner on the receiver (a beomaster 2400) the buzzing goes away, only to return when switched back to phono.
    the problem is exasperated (dramatically) when i touch the arm, or the cartridge, or wobble the platter.
    i just bought a brand new cartridge, (in the hope that it would alleviate the problem), but still... the dreaded buzz.
    any ideas?
    thanks kindly.
  • 10-28-2009 6:47 AM In reply to
    Re: buzzing, beogram 3404 after prolonged use
    Probably an earthing issue. What amp do you have the Beogram connected to, does it have a DIN connection or are you using some kind of an adapter in between?
    -mika
