Hi there
I have a couple of questions:
1) I have a STB-C installed with the latest software to control Sky+ but the only option that appears under sources is the AV socket - so I can't use the second socket to control my DVD and iPOD through a lintronic box - if I upgrade the software in the Avant to name the second socket, is this an easy task?, my second avant 28 is a newer software version but I have no idea where the chip is or how to change it - does this need a dealer and how much would it cost roughly?
2) Could I buy an AV2 Expander and would this allow control of two set top boxes from the one controller?, I read somewhere that it should be possible to control two peices of equipment, so ideally this would be Apple TV through a converter and Sky+ with DVD plugged into another socket
Any help would be much appreciated.
Beovision Avant 32 RF, DVD1, Beovision 1, MX4002, Beound 3000, Beolab Penta MKII, Beovox Penta, Beolit 707, Beolink Passive, Beovox C30, Beocom 4, Beogram TX, 4 x Beo4, Form 1 & 2, Beocenter 7700, Beovox S65,
