Latest post 10-27-2009 2:49 PM by yachadm. 1 replies.
Page 1 of 1 (2 items)
  • 10-13-2009 2:32 PM
    Beomaster 5000 radio doesn't work
    Hello
    I have a problem with my Beomaster 5000 Amplituner. Generally it works fine from about 2 years but still I have been used only phono, desc or CD sources. Today I want use radio and unfortunetly it's not work. When I put cable to the antena input the Beomaster finds few stations (automaticaly or manually) but not stop is silence. 100% silence!
    Any ideas?
    regards
    Tomasz
    Filed under:
  • 10-27-2009 2:49 PM In reply to
    • yachadm
    • Top 100 Contributor
    • Joined on 06-24-2007
    • Jerusalem, Israel
    • Posts 687
    Re: Beomaster 5000 radio doesn't work
    I've just finished restoring a BeoMaster 5000, and almost 60 capacitors needed to be replaced.
    Yours might be in the same boat - starting to show age-related problems - it isell worth it to fix.
    Menahem
    Learn from the mistakes of others - you'll not live long enough to make them all yourself!
