Latest post 10-12-2009 11:49 PM by mediabobny. 4 replies.
Page 1 of 1 (5 items)
  • 10-11-2009 1:19 PM
    • h1npw
    • Top 75 Contributor
    • Joined on 04-16-2007
    • A cricket ball throw from Trent Bridge
    • Posts 776
    Replacement Panels for 5000 / 5500
    I've recently bought some of these off ebay from two different sellers.
    I can thoroughly recomend barrie911 - his panels have a finish that is very close to that of the original panels - if I was being picky I'd say that they lack the slightly grainy finish of the originals - but your nose has to be about 6 inches away from them to tell! Not cheap at £20 but worth it if changing the panel will bring the item back to near mint.
    I would not recomend paul.k2007 - his panels appear to be be painted with some sort of silver metalic piant -  they aren't even lacqured and scratch very easily. They don't look anything like the original panels. They're a lot cheaper (£10) and they look it!
    Cheers
    Nigel
  • 10-12-2009 4:48 AM In reply to
    Re: Replacement Panels for 5000 / 5500
    Thanks Nigel
    That is useful information. How hard is it to remove the old panels?
    Simon
  • 10-12-2009 3:15 PM In reply to
    • Medogsfat
    • Top 10 Contributor
    • Joined on 02-21-2007
    • Posts 4,045
    Not difficult to remove at all Simon. They are held on with B&O's usual cop-out - double sided sticky tapeSmile
    Chris.
  • 10-12-2009 5:02 PM In reply to
    • h1npw
    • Posts 776
    I've only removed 2 panels, one from a Beomaster that came off relatively easily and one from a Beogram that was an absolute pig....it wasn't stuck on with tape,  it was a piece of adhesive that was the full size of the panel. I'm sure NASA used the same stuff to stick the heat resistant tiles onto the space shuttle...how I didn't break the perspex lid I'll never know. I lost a few pounds (wieght) in the process..still worth the effort though.
    Cheers
    Nigel
  • 10-12-2009 11:49 PM In reply to
    • mediabobny
    • Top 200 Contributor
    • Joined on 04-19-2007
    • Greenwich Village, NYC
    • Posts 336
    h1npw:
    Hmmm - those tiles have a habit of coming loose, so I'm fairly certain it IS the same adhesive B&O uses..
