Hello
Firstly this is a fabulous resource - I've seen a fair few forums for many things over the years but respective to product and focus this site is second to none.
I'm seriously considering purchasing the Beo5 remote tomorrow. Having embarked on a self build project, home automation is something I've been looking at for some time but with no real joy respective to controllers that are worth the money. That was until the Beo5...possibly!
The questions
1 - Do you really need a Bang & Olufsen product to start with? i.e. no beovision/beosound product means no control over non Bang & Olufsen products such as Panasonic TV, Sony Dvd etc. Some parts lead me to believe this was the beginning state of the product but not the current one
2 - MasterLink gateway. The main Bang & Olufsen shows a great informational on it but leads me nowhere afterwards. Any experiences integrating this item with other systems and then using the Beo5 to control the whole show?
3 - Configuration tool. Looking at a version available it seems you need to specify a primary Bang & Olufsen product first per zone before putting on the non Bang & Olufsen items. Is this simply to spoof the Beo5 controller or a hard requirement?
4 - Range. I see its IR based so how good/bad is range?
5 - Can you have more than 1 in the same household without issue?
6 - Control. How far has someone taken this unit? For example zoned audio/video control, temperature, lighting etc
7 - Is it easy to return to factory default settings should you encounter programming issues? Speaking from development teams experiences as if we only have one controller its not as if we can treat it like a development/integration item... everything would be a "Release to Production"
Kind regards and thanks in advance for any responses/information
