1st March February 2012
Latest post 10-07-2011 7:14 AM by Guy1680. 48 replies.
09-30-2009 7:56 AM
Uldall`s
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.47.44/avatar.jpg)
![Top 500 Contributor Top 500 Contributor](/Themes/beotheme1/images/rankicons/rankTop500.gif)
![Male Male](/Themes/beotheme1/images/rankicons/GenderMale.gif)
- Joined on 08-17-2007
- Denmark
- Posts 96
![Bronze Member](/Themes/beotheme1/images/roleicons/8373aae9-2be6-4a12-8c67-ab927ce1557e.gif)
Hello Is it possible to use Beo1 to other than beovision1 ....? it is possible to configure it so you get some features to work on other Bang and Olufsen equipment
/Uldall
Beosound century Beocenter2 Beolab2 Beolab3 Beolab8000 Beolab6000Black Beolab4000 Beovision Avant 32 DVD RF MX7000ML MX4200ML MX1500 Beolink1000 Beo1 Beo4 Beo5 Beosound1 Beosound6 Beocom2 Beocom6000 Serene BeoPort A4 A8 A9 LC1 LC2 Kabinet 2168 Black line FORM1 Beotime Beotruck.
stefan
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.99/avatar.jpg)
![Top 50 Contributor Top 50 Contributor](/Themes/beotheme1/images/rankicons/rankTop50.gif)
- Joined on 04-16-2007
- 200 miles from Struer
- Posts 1,733
![Founder](/Themes/beotheme1/images/roleicons/6f51347a-6d4c-4ff4-9d2e-4e3705076d55.gif)
As said before I have reprogrammed my Beo1 to standard Beo IR codes. So I can use it with my BV7-40 MKIII, BS9000...
All buttons are working like Beo4 buttons.
See : http://forum.beoworld.org/forums/t/13515.aspx
Stefan
hebo
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.22.66/avatar.jpg)
![Top 200 Contributor Top 200 Contributor](/Themes/beotheme1/images/rankicons/rankTop200.gif)
- Sweden
- Posts 305
Stefan,
I can´t get it to work.
Would be nice to be able to use the Beo1, not just have it standing as an artpice:-)
I´m pressing Standby+Display+Stop at the same time then
pressing Stop and holding then pressing double arrow right, and release the two
then pressing Display once
Is this the right way to do it???
Carolpa
![](/utility/anonymous.gif)
![Top 150 Contributor Top 150 Contributor](/Themes/beotheme1/images/rankicons/rankTop150.gif)
- Joined on 08-15-2008
- Posts 440
Stefan.
Marvelous trick,
it works!
Hebo, you got the instruction right.
stefan
- Posts 1,733
hebo:
Stefan,
Hi Hebo,
yes you got that right. Strange, some people got it to work, some did not.....??
Mine is working like a Beo4 - but no colored buttons, no EXIT...
Stefan
hebo
- Sweden
- Posts 305
claudiu:
I tried but unfortunately does not work
Claudiu,
we probably have greater luck in other areas![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
Toubro
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.22.64/avatar.jpg)
- Copenhagen, Denmark
- Posts 263
No way...
I know this might not be the most manly thing to say, but I love you guys. I have had my Beo1 ever since my parents BV1 got stolen in 2002, and I have just had it standing as a piece of art, and even though several people have asked me if they could buy it, I have kept it because I think it is so beautiful designed. That I can actually use it again is fantastic. This has really made my evening ![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
At first I couldn't get it to work, because I hadn't seen the last "display" button press, but now it works fine on my Avant. I can't believe it didn't do this as standard, but that it is still capable.
Cheers guys ![Yes - thumbs up](http://forum.beoworld.org/emoticons/21.gif)
hebo
- Sweden
- Posts 305
Uldall`s
- Denmark
- Posts 96
Hey unfortunately I can not get in Beo1 to respond to the configuration ... ![Sad](http://forum.beoworld.org/emoticons/06.gif)
It might be the software..
Anybody knows if there are differences in software from which they are produced...??
/Uldall
Uldall`s
- Denmark
- Posts 96
Yes
Finally I got my Beo1 to work, it work´s perfectly for MX7000 MX4200 ![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
hebo
- Sweden
- Posts 305
Uldall`s:
Yes
What´s the trick?
How did you do?
Uldall`s
- Denmark
- Posts 96
I changed the batteries and tried again and so did it work ...![Big Smile](http://forum.beoworld.org/emoticons/02.gif)
/Uldall
Uldall`s
- Denmark
- Posts 96
/Uldall
Uldall`s
- Denmark
- Posts 96
/Uldall
Dave
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.23.88/avatar.jpg)
- Joined on 04-17-2007
- Brisbane, Australia
- Posts 2,328
Hey how come this doesn't work for me? I've tried it three *edit:seven* times now (battery changed and everything)
- standby+display+stop at same time
- then hold stop and press >>
- press display
Batteries are not flat... i'm baffled! I'm so jealous you guys got it to work! I have a BV3 and BC1 with Beosound 4, my Beo 1 doesn't work after this trick...
Does it have to be done very fast, does standby display and stop have to pressed in order..?
Carolpa
- Posts 440
Dave:
- press display
try:
press standby keep holding it
press display keep holding it
press stop keep holding it
release all of the three
press stop keep holding it while pressing >>
release both
press display
Dave
- Posts 2,328
:( there must be different versions of Beo1. It doesn't work, my serial number is 15665441
Shame really!
Dave
- Posts 2,328
Can anyone post their serial number for those that worked? I think i have one of the first Beo1's out, maybe if i order a new PCB it'll work
mr_anders_son
![](/cfs-file.ashx/__key/CommunityServer.Components.Avatars/00.00.00.21.44/avatar.jpg)
![Top 75 Contributor Top 75 Contributor](/Themes/beotheme1/images/rankicons/rankTop75.gif)
- Joined on 03-27-2007
- sweden
- Posts 1,032
Dave:
- press display
mine works with this![Wink](http://forum.beoworld.org/emoticons/05.gif)
