Latest post 09-29-2009 5:28 AM by Carolpa. 1 replies.
Page 1 of 1 (2 items)
  • 09-29-2009 4:45 AM
    • Sigmund
    • Not Ranked
    • Joined on 06-20-2007
    • Norway
    • Posts 46
    • Silver Member
    SACD from Blu-ray on BV7?
    Does the Blu-ray player on Beovision 7-40 understand the SACD format?
    The B&O docs just say: "Sound wise the Blu-ray player in BeoVision 7-40 supports the following formats: Dolby Digital 5.1, Dolby Digital + 7.1, Dolby Digital True HD 7.1, DTS 5.1, LPCM 7.1. Blu-ray discs with DTS HD 7.1 or DTS HD Master 7.1 will be decoded as DTS 5.1" (http://www.bang-olufsen.com/blu-ray)
  • 09-29-2009 5:28 AM In reply to
    Re: SACD from Blu-ray on BV7?
    if an external BR or DVD player can convert the SACD's DSD format to PCM (2ch or multich) you can listen to it.
    the BS3/BV7-40  can NOT decode DSD. Meaning if you send it to the BS3/BV7-40 as a bitstream you will not hear music.
    This also means that the build-in BR player of the BV7-40 only plays the cd part of a hybrid SACD and NOT the hi-res format of the sacd (as can't most of the BR-players!)
