Latest post 09-22-2009 1:39 AM by tournedos. 7 replies.
Page 1 of 1 (8 items)
  • 09-19-2009 11:25 AM
    Beomaster 900K mutes itself
    I have a nice, otherwise well working Beomaster 900K. Every now and then, usually after extended play, it decides to mute itself. Lights stay on (so not a problem in the power switch), but nothing comes out of the speakers. If I turn it off and straight back on, it always continues to work as if nothing happened, so it doesn't sound like a bad contact or overheating, but rather an internal problem in some semiconductor perhaps...?
    This happens seldom enough to not be a big nuisance, but I would spend some time trying to fix it if I had the faintest idea of where to start. Oh yes, this is always when listening to the radio, I don't have any other sources connected.
    -mika
  • 09-20-2009 2:35 AM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 900K mutes itself
    Try tapping the AF transistors gently with f.e. the handle of a screwdriver
    next time it mutes.
  • 09-20-2009 6:42 AM In reply to
    Thanks. The problem may take days to surface, so this will have to wait until winter when I bring it home from the summer house and can keep its guts permanently on display Smile
    So you support my theory of some transistor shorting internally? I have two more 900's so I could of course try to swap stereo decoder boards to further isolate the problem... the problem must be before it or in it as both channels go silent.
    -mika
  • 09-20-2009 10:32 AM In reply to
    • Dillen
    • Posts 5,008
    Yes, most likely one of the IF transistors.
    Of course, there could be many other reasons but that would be my first try.
  • 09-21-2009 2:11 PM In reply to
    Hi Mika/Martin,
    I have exactly the same thing that happened to an immaculate BM4000.
    Turn it on, tune a station -perfect, then after a while... click, nothing!
    Reboot, try again, plays fine for a while then... click again.
    I never got in to look around, but was leaning towards the IF FM tuning. I would be very interested to hear how you get along with this. In the meantime (when I get a chance) I will open it up and try the tap trick!
    On another note, pardon my ignorance... but is there a proper technical term for (let me try to decribe it)... Say you're tuned into an FM station, and particularly with some treble dialed in, you get a faint background variable whining... almost sounds like frequency tuning? It does not exist on any other sources. Some sort of interference between the tuner/power supply?
    edit: Heterodyne whistle?
    Thanks in advance,
    • B&o bottle opener
  • 09-21-2009 4:45 PM In reply to
    • Dillen
    • Posts 5,008
    The BM4400 does not have AF transistors so is not prone to
    this type of failure.
    It will have to be something else. A cracked solder joint, a heavy tuning
    drift outside of the AFC reach or some muting fault.
    Yes, that's the whistle.
  • 09-21-2009 4:51 PM In reply to
    Dillen:
    ARGH!
    Sorry for the red herring Mika! ...and I was all fired up to go tap-tap tonight! Laughing
    I guess at this point, I'll lean toward a cracked solder and have a look around when I have a chance... I'll put it on the "back burner" until then, as I was hoping it might have helped Mika and myself at the same time.
    Dillen:
    Ah! Thanks for the confirmation, Martin!
    • B&o bottle opener
  • 09-22-2009 1:39 AM In reply to
    No problem Jeff - you need to get something older so you can tap as well Laughing
    -mika
