Hi!
I am new to Beoworld and to Bang and Olufsen products in general, and a brand new audiophile.
Recently I have decided to make use of some old records and have bought a Beogram 3404 on eBay.
However, since I'm new to this, I am not sure what kind of amplifier I should buy, since this turntable is over 30 years old.
Can I use any modern amplifier or do I need a special compatible one and which one would you recommend?
The person who sold me the turntable oly told me this:
''If it's a turntable that has a moving coil cartridge in it then you
would need compatible amp that goes with it, for the moving coil
cartridge if it does not have that then you can use the modern amps.''
Since it has an MMC cartridge, which I assume stands for moving coil cartridge, it probably needs a compatible amplifier.
Hopefully you can help me with this and please bear in mind I am new to this and not a very good technician. :)
Thank you.
