Latest post 09-11-2009 9:13 PM by elephant. 3 replies.
Page 1 of 1 (4 items)
  • 09-07-2009 12:10 AM
    Beolink Wireless
    Hi all,
    Is there a way to use BEOLINK Wireless to stream Music from my iMac to a Beosound 3200? The idea is to use Masterlink Connection from iMac (how to connect to Beolink?) to Beosound.
    Thanks for all hints!
    Heribert
    BeoVision 8-40 / BeoVision 8-32 / Beovision 6-26 / BeoSound 3200 / BeoSound 1 / BeoLab 3 /  Beolab 6000 / Beolab 2000 / Beoport / Beomedia 1 / 3* Beo4 /BeoCom 5 with VOIP
  • 09-07-2009 2:26 AM In reply to
    • mbee
    • Top 50 Contributor
    • Joined on 04-18-2007
    • Paris, France
    • Posts 1,133
    Re: Beolink Wireless
    Why not using Airport Express?
  • 09-11-2009 4:07 PM In reply to
    If you already have a wireless network (and your Mac is wireless) then all you need is an Airport Express ($79 as I recall), itunes, and a cable to connect from your B&O Aux to the AE.
    Works great - in fact, you have have a iPhone or Touch, you can control your play lists (and volume) with it.  You can also stream music all over your house.
    Easy as boiling water......
    -michael
  • 09-11-2009 9:13 PM In reply to
    You can not link the Mac into the Beolink Wireless, but you can interface the Airport Express into your Beosound's AUX input.
    I have a B&O ML + B&O Wireless + Apple Airport Express + Netgear cable router/wireless setup that works well.
    (Right now playing iTunes from this Mac wirelessly to Airport Express into the BeoSound 4 and then to the BeoVision 8's Beolab 3s via ML)
    First B&O (1976) was a Beogram 1500 ... latest (2011) change has been to couple the BL11 with the BL6Ks *sounds superb*
