Latest post 09-05-2009 6:38 PM by Michael . 4 replies.
Page 1 of 1 (5 items)
  • 09-05-2009 9:09 AM
    Beomaster 700
    I have just had the pleasure of picking up a Beomaster 700 in an old junk shop for $25, turned it on ...AMAZING sound quality, no hum , timber beautiful and have cleaned it up, externally...can anyone help me understand HOW can I get to the inside , particularly access to the tuning bar that just hangs there and cannot move. It must obviously move on a string or wire... Its so well made, I dont see how I can get inside...
    REALLY appreciate any information// Thanks in advance for any help!
  • 09-05-2009 1:30 PM In reply to
    • Dillen
    • Top 10 Contributor
    • Joined on 02-14-2007
    • Copenhagen / Denmark
    • Posts 5,008
    Re: Beomaster 700
    Note that there are two dial pointers. One for AM and one for FM.
    Only the selected waveband pointer will move.
    The chassis will come out of the back.
    Remove screws at the bottom and, depending on version, the four rotating knobs
    on the front.
    About 10cm out, you will have to undo the plug for the speaker since it will stay in the cabinet.
    Lovely radio !
  • 09-05-2009 1:38 PM In reply to
    • Evan
    • Top 25 Contributor
    • Joined on 12-15-2008
    • Ohio | USA
    • Posts 2,601
    • Gold Member
    Re: Beomaster 700
    Welcome to the forum! What a great way to get started!
    Evan
  • 09-05-2009 6:37 PM In reply to
    Re: Beomaster 700
    Thanks Dillen, Its most helpful.
  • 09-05-2009 6:38 PM In reply to
    Re: Beomaster 700
    Thank you Evan.
