Latest post 08-26-2009 11:41 AM by Chrisreunion. 2 replies.
Page 1 of 1 (3 items)
  • 08-25-2009 5:06 PM
    • bossbrad
    • Not Ranked
    • Joined on 07-02-2009
    • Colorado, USA
    • Posts 57
    • Gold Member
    BeoLab 2500 vs BeoLab 4
    Hello I am looking for a small system to put in my bedroom and I already have a BeoSound/Center 2300 and was wondering which was a better speaker.
    Thanks,
    Brad
  • 08-26-2009 1:41 AM In reply to
    Re: BeoLab 2500 vs BeoLab 4
    To match with your system i would choose the beolab 2500.
    If you are not looking for the better visual match i would choose the beolab 4. I like the sound and design. I self use them in my bedroom and i am very happy with them. Don't forget to work on a good setup. It makes a big different on the beolab 4. I heared them in the shop and didn't like the sound. At home i looked for the wright setup and the sound is good. I went back to the shop for listen again and again they didn't sound good. So make a good setup.
  • 08-26-2009 11:41 AM In reply to
    difficult choice indeed, since the BeoLab 2500 will be better looking with the BeoSound you have, they were designed to complement each other; however, having owned both, I find the Lab 4 much more dynamic, alive, with deeper bass and crisper treble, and they also have much more placement options, not to mention the power consumption!
    Reunion Island is greeting you!
Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly Need a cable? Just ask Steve at Sounds Heavenly
