Hello!
< will not forward the carriage much > on the other hand works. Also playing is possible at times but most of the time during playback the carriage does not forward, it will get stucked. I figure that fastforward < is more likely to fail than play, (same direction) cleaning doesnt seem to help (rails, cleaned, wheel cleaned, rifled bolt cleaned, etc. )What could be the fault?
