Hi all -
I was finally able to power up my Beomaster 2400, cx50 speakers and Beogram 1602 turntable.
The good news: everything appears to work.
The bad news: what's coming off the turntable sounds like hell.
I haven't done my basic due diligence yet - because the equipment is in my office in the bowels of a tv station, I haven't hooked up an fm antenna (reception is poor, as you'd expect) so I can't absolutely rule out the 2400 as the problem.
That said, I suspect the turntable. It sounds to me like I don't have the weighting set up properly, and the B & O directions aren't of much help.
The cartridge is marked 20EN, which shows a tracking weight required of one gram.
Can someone carefuly walk me thru' setup?
Thanks,
Scott Atkinson
Watertown NY
